RE: Balancing-Am I a bubble off?
FALSIFY,
THE WAY I HAVE BEEN BAL. ALL OF MY PLANES IS TO PICK THE PLANE UP BY ETHER THE WING TIP'S OR LIFTING IN THE SAME DISTANCE BACK FROM THE LEADING EDGE NEXT TO THE FUSE BUT MAKE SURE THE WING IS BALANCED BEFORE YOU FLY IT MEANING CHECK THE BALANCE OF THE WING WITH THE WING OFF THE FUSE BY HOLDING THE CENTER SECTION OR WING JOINT AND SEE IF IT FALLS OFF TO ONE SIDE IF IT DOES CORRECT IT IVE SEEN PLANES GO DOWN BECAUSE OF THAT,,../ BUT WHAT YOU WANT IS A SLIGHTLY NOSE HEAVY BALANCE WITH THE FUEL TANK (EMPTY) ARE YOU FLYING OFF OF GRASS OR PAVMENT
USE DAVE BROWN LITE WHEELS 3 TO 3.5 IF YOU ARE FLYING OFF GRASS GOOD LUCK AND IF YOU NEED A
INSTRUCTOR LET ME KNOW I'M NOT TO FAR FROM YOU
JIM
