RCU Forums - View Single Post - ARF Hardware
Thread: ARF Hardware
Old 03-22-2002 | 12:10 PM
RICEC5
Default ARF Hardware
I have a H9 Cap 232 1/4 scale near ready for equipment installation and a Lanier Edge 540 on order. Bothg planes use entirely different control horn hook ups. The Cap uses a metal version of the typical Du-Bro style control horn. The Edge uses a 4-40 bolt that goes through a hard point on the control surface, and is retained by a nut. A nylon fitting with a hole for the clevice is then threaded onto the bolt. Are you guys using this stuff, or changing it out? If changing..what are you using? I also need a source for CF pushrods for the elevator for both planes...
Joe
