RCU Forums - View Single Post - Rib stitch help
Old 01-30-2009 | 07:58 AM
TomCrump's Avatar
TomCrump
Default RE: Rib stitch help
ORIGINAL: jim52519
I understand how it is done on real planes. If I could do it over I would use the method of thread under the pinking tape. The directions from F&M suggested putting the glue on top of the pinking tape with a T pin. That is why I went this route. I need to know how to make this method work. I can not put anything under the pinking tape at this point.
Jim
Give TiteBond III a shot. I've had better luck with it, as it hasn't created the "volcanoes" for me.
While the T-pin method works well, I use a syringe available from Gary Sibert. http://www.pink-it.net/ They come with his pinking tapes, but are available for separate purchase.
ID:	1123000   Click image for larger version
