Nitro model extra 300s manual
I have completed a Nitro Extra 300S plane. The manual that I received with the plane was for a 40 size plane (1440mm wing span) but the plane I received is a 60 size aircraft (Approximately 1610mm wing span). My only problem is I do not know what the recommended
CG is for the larger plane - can you please forward to me at what point I should set CG?
Sonnytex
