RE: JR 9303 programming help
#1 Go to WING TYPE: NORMAL
#2 Rotate the Roller until you are
under AILE, Press the Roller
and Select AUX2, rotate the
Roller until you are under FLAP,
Press the Roller and select AUX3
(you have the choice of
selecting TRIM or INH..this
might help trimming the FLAP on
AUX3)
#3 Go to DEVICE SELECT and Rotate
the roller until you are under
AUX2(on the bottom of the screen
Press the Roller and INH AUX2,
Under AUX3, Press the Roller and
INH AUX3
#4 You may have to REVERSE AUX2 or
AUX3 or both depends on the hook
Up of the linkage.
#5 Just remember that any change on
Aileron Travel adjustment, has
to be done on AUX2, and the same
for Flaps and AUX3.
#6 NOTE: Connect Right Aileron to
Aileron, and Left Aileron to
AUX2. The same for the Flaps,
Right FLAP to Flap…Left Flap to
AUX3
