RE: JR 9303 programming help
FLAPERONS/FLAPS/ELEVATOR
Go to Main Menu.
Go to WING TYPE: Set Wing to FLAPERONS.
Go to Secondary Menu.
Rotate roller to FLAP SYSTEM: Rotate until ELEV Land, press roller down, rotate until it reads D 10 o/o, Press
Down on roller.
Rotate until FLAP Land, press roller down, rotate until it reads D 50 o/o,
Press down on roller.
Rotate roller until you are at LST, Press roller, rotate until you are at Monitor, Press roller, now you can monitor the action when you press the FLAP Switch down, the Ailerons will droop, and slight down Elevator.
NOTE: The amount of FLAP and Down ELEVATOR, must be test flown first to
ADD or SUBTRACT..Flap or Elevator.
