ORIGINAL: Big-Mo
Hello Looking for the best place to get programming guide info for a Jr 9303 synthesized radio when it gets here. just trying to get a jump on the reading.
any input or help locating the best guides would be appreciated.
mainly. got several models with 6 servos 2 ailerons 2 elevator 1 rudder and one throttle.
I am in no way being sarcastic, but the manual covers all those items fairly clearly. One thing I would recommend is to start at the begining of the airplane section and go step-by-step through the model setup. You'll find that certain switches may need to be inhibited or activated to allow your particular setup. If you did not properly set up your transmitter in the first steps, then some later choices you want to make may not be available.
