what airbrush to get?
Would the iwata hp-c airbrush and the sprint jet compressor be good enough for doing lexan bodies? Would the eclipse cs be a cheaper but good alternative? Are the gravity feed brushes necessarily "better"? If you can suggest a better setup that is cheaper or around $300, please do. I will most likely order from dixieart.com.
