RCU Forums - View Single Post - ~~~"Blade 400"~~~
Old 02-01-2009 | 12:43 PM
kruser495
Default RE: ~~~"Blade 400"~~~
ORIGINAL: rotarydoc
Josh,
Almost forgot, I think you made a good choice on the B400 over the Belt CP....I'm sure the Belt CP is an OK helicopter, and the price is definitely right, but I just think that you'll get alot more for your money if you spend a bit more on the B400...
The radio alone is the main reason I would go with the B400..it's a radio you can grow with...I use it on my Trex 500 now....but when I bought the B400, I never gave that a thought, I was like "why would I ever need 10 different models programmed into the radio"?
Well, I now have nine models in my DX6i!! So, you can see that the radio itself is good reason in itself. Not to mention parts availability, excellent customer support, and a huge knowledge base right here in this forum too...
Congrats again on the soon to be yours B400!
Glenn
thanks. i was kind of curious on how 3d works. the rotors are pushing air down so when you go inverted, shouldn't it make you go into the ground?
