RE: Yet another parallel lipo question
I just thought of something: Is there a possibility that I could "over-drain" the smaller battery? The ESC will cut the power once it sees its input voltage drop too low, but when the smaller battery drops to its lowest limit, the overall voltage will probably still be above the ESC cutoff.
"Over-draining" or dropping below the min voltage is bad for lipos, right?
Brady
