RE: P70 Error code and subsequent self destruction
More pics of the removed turbine...
As you can see, it looks like the impeller at the front is pushed 2-3mm to one side! A couple of the blades do have little nicks out of them but I can't tell if this is an indication of something being sucked in there causing this or if something was sucked in there as a result of this.
I'm thinking I'll take this to bits myself as I'm pretty sure that Jetcat Warranty does not cover this and it has expired anyway.
I don't think the shaft has broken because the front impeller and the rear exhaust vanes cannot be turned.
[link=http://www.georbeckha.com/P70Logs/Top.jpg]Top[/link]
[link=http://www.georbeckha.com/P70Logs/Underside.jpg]Bottom[/link]
[link=http://www.georbeckha.com/P70Logs/Front1.jpg]Front 1[/link]
[link=http://www.georbeckha.com/P70Logs/Front2.jpg]Front 2[/link]
[link=http://www.georbeckha.com/P70Logs/Front3-gap.jpg]Front showing the Gap[/link]
George
