RE: The Man Cave
What are you going to put over the OSB since it cannot be exposed to the elements for very long before it takes on moisture and starts to swell and debond. It is usually used on roofs where felt paper and shingles will be covering it up. I have seen it used as a siding base, if that is what you are using it for then it will work out great.
