Help! A question about wood wings
I assume that the plane has obechie-sheetd foam wings. The covering of choice with that sort ofi wing construction is Ultracote/Oracover. It has a lower application temperature than Monokote and is more foam-friendly for that reason.
Unless you are experienced with glasing and painting, or have ready access to replacement wing panels <g>, I'd avoid glasing the wings.
