RE: Fuel proofing and hinges
Is this correct! I install these little ca hinges in the wing and the aleron after
I made the slits and drilled a 1/16 " hole in the center of each slit.
now I tilt the aleron and drip ca thin into the holes in the elevator and wing,
then do I need to turn the wing over and do this again? how do I stop
the aleron from being glued to then wing what happens if I use to much ca.
Is it easer just to go to my local hobbie shop and buy better hinges.
