RE: Is my UAT mounted ok?
OR, perhaps, IF the line is kinking due to the radius then you could use a brass or aluminum tube for the 90 bend portion, avoiding a re-make of the whole tray. The easiest way would br to use an aluminum 'T' fitting with on leg plugged off. Nice tight turn, no kinks.
