RCU Forums - View Single Post - aileron to main wing gap
Old 02-03-2009 | 10:51 AM
bruce88123
Default RE: aileron to main wing gap
ORIGINAL: icarus98
looks like i screwed up royally there!
so, on this subject, i only set in one of the ailerons...........should i seat the other in properly as it should be, or do another 4mm on the other side to keep the lines uniform??? can't believe i did this! what a pain..........!!
I'd do the other side correctly. Get used to doing it right. Then if all goes well you COULD consider simply cutting off the hinges on the bad side and installing new ones adjacent to the old ones. Not needed but doable.
