RCU Forums - View Single Post - Setup for jumping??
Old 06-08-2003 | 05:06 PM
adeoliver
Default Setup for jumping??
I run on a crazy track like that, with 5' table tops, 4-5' doubles 10' long, and get 10+ air off of the doubles at 3/4 throttle.
The best thing you can do is to stick 60+ shock oil in, and put some heavy duty springs on or add another spacer per shock!! My shocks run at about a 55 degree angle. This truck will fly strait and true with this setup, but Ive also got the weight pretty much evened out. Now the one thing to remember on these kinda tracks is bring lots of spairs, because you will tumble you truck, and unless everything is up to par, you will break something if you going for 10' jumps, and if you are still eunning those 3.5 punisher turnbuckles with stock ball ends, make sure you run a bead of super glue around the threads, or you will probably end up looseing a few rod ends!!
