RCU Forums - View Single Post - I cant get my engine to start
Old 02-03-2009 | 10:03 PM
aussiesteve's Avatar
aussiesteve
Default RE: I cant get my engine to start
Yep
you mention the tank is "pressurised". You should have a vent to atmosphere and a line to the carb - are you trying to use exhaust pressure to feed the fuel?
If the tank vent is clear, I would consider the fuel diaphragm this is the most likely place to start- possibly the needle height in the carb too.
Check for leaks around the carb mounting and crankcase - these could appear when the engine warms up - use a good sealing compound.
Start again with the tuning - start at 2 turns out on each needle and adjust in small increments
