RCU Forums - View Single Post - ENGINE OFFSET ??
Old 02-04-2009 | 08:11 PM
Tired Old Man
Default RE: ENGINE OFFSET ??
Center the prop shaft in the cowl. The kit likely already has right thrust built into the firewall. If you built it yourself and did not add right thrust to the firewall about 2 degrees will be just peachy.
