RCU Forums - View Single Post - !:25 PB65
Thread: !:25 PB65
Old 02-04-2009 | 08:52 PM
toesupwa's Avatar
toesupwa
Default RE: !:25 PB65
ORIGINAL: yachtie2k4
its going to be 853mm long, and 231 wide. what kind of motors would i need, what sort of esc would i need, how to i wire these up to hitec reciever, how do i make a stuffing box. how do i do lighting inside and around the boat?
Hi Rob
As Pompebled said, most of your questions have already been covered on these forums..
Motor / ESC selection depend on the style of hull and its weight... after selecting a prop to match the boats type and required speed.
Wiring an ESC to a Rx is easy, it just plugs in to the throttle channel on the Rx
A stuffing tube can be made from two brass tubes, one piece fits inside the other (as bearings at either end) and fits your prop shaft.... what size do you need and are they available comercially?.
What type of lighting?.. LED or incandecent?... number of lights?... again, we need more info as to what you are trying to achieve.
