If I remember correctly start with the top RH cover use a small (Jewller) flat blade driver in the middle, the cover just clips up, then the rest will open up.
Go slowly and before lifting the cover up take note on the batter lead placment...I had a lot of trouble with this....The battery lead are the only red and black wires.
I have taken photos of the clips will give a link.
http://www.rcuniverse.com/gallery/ga...emberID=435507
save it to windows pics open it the scroll to enlarge it to the size of the cam and you now have the exact postition of the clips....
The clips lock on to the top cover so press the clips in the middle section of cam.
Clips are marked white..
I wish I knew this before i broke the clips....
