RCU Forums - View Single Post - Kyosho Stadium Truck
Old 02-05-2009 | 09:17 AM
rclynx's Avatar
rclynx
Default RE: Kyosho Stadium Truck
I do a lot of running on cement or pavement M8 and unless the surface is really smooth those rib tires grab just as good if not better than any of the other rubber tires do. If you can get them cheap enough and can add a few ounces to the front foam can have almost an unreal effect for the front end.
