RCU Forums - View Single Post - Top Flite Staggerwing
Old 02-05-2009 | 11:45 AM
  #914
knucklebutt's Avatar
knucklebutt
Default RE: Top Flite Staggerwing
O.K. Gang: here's the scoop on the Spektrum/JR retract issue
The folks at JR say (drum roll please) you have to bind you're transmitter to receiver with the retract switch in the DOWN position as well as your landing gear also in the DOWN position. That way when the units are switched on it will recognize the gear as "Down"
see if that helps !!
Denis
