RCU Forums - View Single Post - adding weight
Thread: adding weight
Old 06-09-2003 | 06:05 PM
greenboot
Default adding weight
The thought of adding weight makes my teeth curl up! NONE of my planes have any extra weight added. Yet some people have weights everywhere you look. I just don't get it.
If you think CG is that critical, consider that it moves a half inch or more as fuel is burned off. Can you really tell that if flies different at the end of the flight? I usually can't.
OK, I realize it must balance within the recommended range. But I don't understand the need to add a couple washers.
Tom
