engine starting problems
A few days ago I wanted to start with braking-in my LRP truggy engine. But it didn't went smooth.. at all... I couldn't start the engine. The pistion was stuck at the top. The flywheel just stopped at the top and the rubber flywheel of my starterbox just continues with spinning. You can see fine rubber on the chassis that is scraped off. I managed to start the engine 2 times though. The first day it started after many times trying and stopped after 2 sec. and the second day it started but when I removed the glowplug ignitor it stopped...
I tried al the tricks.
- pre-heating the engine (~ 150 fahrenheit, or 65 Celsius, this was the max temp I can get with a hairblower)
- loosening the glowplug a bit
- turned the fleewheel so it has a run-up
- Let the starterbox spin for a couple of seconds before pushing the car down, so it reaches max rpm
The starterbox is not the problem, cuz it's powerful enough as you can read. (it's the Ofna starterbox btw)
2nd Question: Do you think my engine is already damaged after al these (failed) attempts? Cuz it gets jammed with some force to the top ,but most of the time it just won't turn further... Thanks, appreciate all the help
