ORIGINAL: knucklebutt
O.K. Gang: here's the scoop on the Spektrum/JR retract issue
The folks at JR say (drum roll please) you have to bind you're transmitter to receiver with the retract switch in the DOWN position as well as your landing gear also in the DOWN position. That way when the units are switched on it will recognize the gear as "Down"
see if that helps !!
Denis
Okay, you may now picture me slapping my forehead while asking "Why didn't I think of that??". I'm going to test this right away!
Thanks so much for the info Denis! Most appreciated!
