RE: seagull extra
Pictures would help us understand exactly what you mean. If you are refering to 6mm tall and running the entire length of the wing or 6mm deep into the wing or a little 6mm block at intervals along the trailing edge. either way, if you can install your hinges without forcably splitting the wood you will likely be okay. However, pictures would help a lot.
