RCU Forums - View Single Post - what is chordwise
Old 02-06-2009 | 12:40 PM
richg99
Default RE: what is chordwise
One method to remove items that are glued on..... is to take a cheap plastic box cutter and heat its blade ( propane/heat gun/wife's hair dryer, etc. ). Use the heated blade to cut through and loosen the glue. You may have to re-heat the blade a number of times to get all of the way through the glued joint. rich
