RCU Forums - View Single Post - Need help with thrust problems
Old 02-06-2009 | 09:24 PM
jetmech05
Default RE: Need help with thrust problems
how sensitive is the plane to pitch inputs?...sounds like it maybe a CG problem since the airplane still wants to climb with power off.....has the plane always acted this way or is this a new problem?.....As TFF said how is it inverted..if she climbs inverted...then you are indeed tail heavy
