RCU Forums - View Single Post - super charger for savage X
Old 02-06-2009 | 10:21 PM
nonyabiz
Default RE: super charger for savage X
A super charger aka blower dose not pressurize the engine it compresses air and forces into the engine much like a air compresser would. As to if it would work on a two stroke it is hard too say in theory it would because all it is doing is forcing more air into the engine it self but i would assume that it would lean the engine out too much.......I dont know too much about these engine yet but i do know a little about blowers and there is no real reason as too them not working i would say that the blower would be so small that you wouldnt see any diff. and that this engine turn way too many RPM too keep a real blower together i know they put a larger pully on them but still you would make a ton of heat with that those kind of RPMs on a blower that is really compressing air...just imo
ooooo sorry i just thought of it...your right it would blow fuel out the exhaust the blower would always be making pressure and only has one cylinder too put it into so when the exhast port is open it would push fuel out the exhaust you would need a engine with more then one cylinder and valves
