RE: Servo "buzzing" noise...
make sure that when you move the sticktravel in both directions makes a differemce in throw, from3/4 to full , should notice in ancrease if not then you are binding, which a computer transmitter can be dialed out.... if not , then you might to go in on the servo arm, or go out on the control surface arm
