BME 102 carb adjustment problem
If the baffle helped then maybe you still have some turbulent air near the carburetor, I suggest a soldered tube on the carb vent hole instead of the baffle and run a line from the soldered tube to the canopy area, this will assure undisturbed air for the vent and may help with the midrange running.
Bill
