RCU Forums - View Single Post - Throws for 3D Edge 540 .46
Old 02-07-2009 | 07:50 AM
CGRetired's Avatar
CGRetired
Default RE: Throws for 3D Edge 540 .46
ORIGINAL: opjose
Careful there...
I would recommend setting throws to RECOMMENDED levels and then use the low rate setting of your TX to lower that to about 50-60% of that.
This way if you find that the plane is not responsive enough for a safe landing ( e.g. you don't have enough up elevator to maintain glideslope ), you can always flip to high rates to bring it down.
However by starting off at the lesser than recommended rate, you get the same effect as what CGretired is suggestion.
When I said minimum throws, I assumed the poster understood, from a common sense point, the meaning of minimum was what was recommended by the model manufacturer.
