ORIGINAL: Dorian AM
Hi Likai,
I have the intruction manuel, the translation is difficult for me.
I connected it like that
Recever GYA352 Servo
axis Y = Elevator \ / Vector thrust left
mixing ALV
axis X = Aileron / \ Vector thrust right
the gyro control axis pitch and axis yaw and not axis roll and axis pitch????
Hello Dorian:
From Your picture of fixing GYA-352, now I know your fixing and connection of GYA-352 is correct, but you just confuse the meaning of "yaw" and "roll" in English. The "yaw" is the motion of airplane that driven by rudders or nozzles moving left or right, the "roll" is the motion of airplane that driven by ailerons or nozzles moving differentially.
So, the GYA-352 is for pitch/roll control in this case and the yaw motion of nozzles should be driven by the other two servos located on the side of two nacells which are controled by another one GY-401.
Do you have another one GY-401 in your plane?
Best regards
