RCU Forums - View Single Post - applying koverall with WBPU
Old 02-07-2009 | 11:45 AM
andrew66's Avatar
andrew66
Default RE: applying koverall with WBPU
ORIGINAL: bgfireman
andrew66,
AI was just wondering if you have covered your plane yet with the wbpu yet. If so how did it turn out? When you mix it with the water approx. how much water to wbpu do you mix.
Alan
Im in the final stages of my build (kadet seniorita build) so i will be covering soon. I dont mix any water. just apply it full strength.
Rcdude: If you are using latex, i dont think that you will need primer. just make sure the surface will allow the paint to adhere. From what ive read, only 2 coats will fill the weave on fabric.
