Meter on power panel question
when setting the temp for the glow starter ,keep in mind that most glow plugs are rated at 1.5 volts .
there are some that are rated as high as 2 volts be careful not to burn your plugs out by putting more than the rated volts , the knob that is there adjusts the volts that you put in !!!!!!
Highlander
