Meter on power panel question
Highlander,
Voltage = Current times Resistance. You can't have one without the other. So you cannot feed straight amperage or voltage. In the case of a glow plug its resistance is low. If you feed the plug 1.3 to 1.7 volts you will see a larger current swing. Because of the larger current swing, that is what is monitored on most control panels. Not voltage.
Later,
John
