RCU Forums - View Single Post - 3blade for 110
Old 02-07-2009 | 11:59 PM
Tommy_Gun's Avatar
Tommy_Gun
Default RE: 3blade for 110
May I suggest you view this video with regards to your H9 Spitfire?
http://www.youtube.com/watch?v=t-6pp...e=channel_page
Make sure you have the elevator joiner properly installed. Consider replacing the joiner with a stiffer piece of music wire.
Make sure your hinge gap is as tight as possible.
Consider using a dual pushrod to each half of the elevator.
Also think about stiffening the horizontal stabilizer with gussets or sheeting.
Try to avoid a straight down mounting of the cylinder head. I am just guessing that this particular plane may have had a unique vibration situation with the YS mounted with the cylinder pointed down and that this coupled with other possible contributing factors made the flutter fatal.
I know this is the YS engine forum. I run almost all YS four strokes on my planes.
The plane in the video was brand new with a new YS 1.10S in the nose.
Good luck.
