RCU Forums - View Single Post - zenoah 26EI
Thread: zenoah 26EI
Old 02-08-2009 | 01:14 AM
tkg
Default RE: zenoah 26EI
You missed the pump port. If you look at the carb in its normal position, you will see that the little hole in the intake matched the hole in the carb. If you turn the carb over then the wrong hole lines up.
