RCU Forums - View Single Post - Very Bad, CMP AT-6 Texan
Old 02-08-2009 | 08:49 AM
  #60
br310
Default RE: Very Bad, CMP AT-6 Texan
HI LDM,
How are today?
Like i said before last august I did send a message and picture to everybody that I was thinkig of and I had a reply that i was not expecting from Raidentech.
Now if you think that you have some power or that you have any contact with those guys of CMP, please go right head and send them the following message that I did on the 25th of last august.
If you look carefully you will see the jackie adress.
below the dash line you will see the reply 3 days later.
Many thank's
Bruno.
- Original Message -
To: [email protected] ; [email protected] ; [email protected]
Sent: Monday, August 25, 2008 5:31 AM
Subject: Very bad, CMP AT-6 Texan
I have bought from Nitro planes an CMP AT-6 Texan last winter and I did 6 flight of 10 minutes minimum each time and the last flight i was straight and level and the fiberglass mid section of the wing fold in flight. The tip of each wing almost thouch together. Nothing I could do to prevent this because we can't see what's inside that portion of the wing. It is simply and badly built because there is no plywood former and even no main spar, only cheap balsa ribs cover with fiberglass. This specific section is structural, it as to take's all the weight and stress of the aircraft and it’s the weakes one. Of corse my Zenoah 26 ei was hurt in the crash like other parts. I'm realy sad because I have nothing to do whit that crash and also because that plane was fliying very well.
Many thank’s CHINA MODEL PRODUCTIONS I will remember.
Bruno Roberge
1846 rte Paquet
St-Nicolas, QC
Canada, G7A 4T7
Thank for the picture but sorry your plane was ordered last year so we can't do anything about it. I can give you a discount 10% off for future order as a good faith but i cannot help you on the AT-6.
thank norman
From: Raidentech.com Raidentech.com <[email protected]>
Sent: Thursday, August 28, 2008 4:31 PM
Subject: Fw: Very bad, CMP AT-6 Texan
