RCU Forums - View Single Post - axe cp thread
Old 02-08-2009 | 11:14 AM
  #1940
smoke157
Default RE: axe cp thread
Yes, both crystals are the same and plugged in. The heli does nothing at all but click once when hook up the battery. I know the batteries are good because if hook them directly to the tail motor it will start spinning. There is no green light on anywhere. I'm starting to think the e-board is bad. So much for my "good deal".
edit/update
I unhooked the e-board from the heli completely and plugged in the battery to the e-board with nothing else connected and the green light started flashing. Could a bad motor or servo cause this?
edit2
I reconnected everything to the heli. Now the green light works but it just flashes and will not go solid. Also, I still get no response from any servo or motor. Is there any way to test the receiver to see if its bad? I don't have another heli to take the rx from and test. I do have a t-maxx and a revo. would one of those rx work just to test?
