RE: axe cp thread
Are the batteries in the transmitter new? Sounds like its not recieving a signal. You are turning on the transmitter first, right?
You should verify the voltage of the Axe battery also. As little as 5 volts could make the tail motor run, but not be enough to run the Eboard.
I'm sure there is some way to swap recievers to check operation, but that's up to you.
Joebe,
You can unplug the motor to remove it too. Remove the front servo and you'll see the two bolts holding the motor in place. To reinstall, place a piece of paper between the pinion gear and the main gear to set the spacing and then tighten it down.
