RCU Forums - View Single Post - Lado retracts, do the really exist?
Old 02-08-2009 | 04:15 PM
phatbob02
My Feedback: (126)
Default RE: Lado retracts, do the really exist?
ORIGINAL: Michael211
I have a question though... how do you decide which strut diameter size to order? Is it better to go with the larger diameter strut size (since I'll have to buy new struts as well, once the LADO's are back in stock again)?
Thanks!
- Michael
Michael,
I would always go with the 3/16" wire if I could.
I'm using Lado's 60-2T on a 15lb Corsair. With this weight I needed a Robart 660 Robo to handle it. They're rated at 18lbs. The 2T's are only available for a 5/32" wire. The 660 strut is a 3/16" wire. I thought I could drill out the retracts but there isn't enough stock at the retract trunnion. I made my own wires with a 5/32" wire and soldering a 3/16" x.014 wall brass tube over it.
Another benefit of the larger strut was the fact that the I.D. of the 660 would fit snuggly over the brass fitting on top of the lado, making for a very clean looking install.
ID:	1130486   Click image for larger version
ID:	1130487   Click image for larger version
ID:	1130488   Click image for larger version
