RE: Ryobi spark plug
There's been a lot of different plugs in them over the years
Mine had a Champion RDJ7Y taper seat plug but some of them have gasket seat plugs. Actually they will interchange on the engine as I have ran both. There wasn't any rpm difference
The gasket plug would be a CJ instead of a DJ The DJ is.325 reach and the CJ is 3/8" reach
Make sure you have the resistor (R) plug or there'll be radio problems
The "Y" is a projected tip
The threads are 14mm
