RCU Forums - View Single Post - Practical difference?
Old 02-09-2009 | 09:42 AM
tIANci's Avatar
tIANci
Default RE: Practical difference?
The practical difference? Hmmm ... let's try this. We assume that you will use a fixed amount of cells for the motor. For this reason we say its perhaps 10 cells.
1. The 3019-12 will turn a bigger prop than the 3019-10.
2. On the other hand, you can always use the 3019-10 with less cells to turn a certain prop compared with the 3019-12.
3. If you want some speed then take the 3019-10 to turn a smaller prop at a higher RPM. Whilst the 3019-12 will give you more thrust with a bigger prop.
I hope this helps.
