ORIGINAL: Albatross1
Hi Scott and
JS,
I think onboard video is a problem if you have it, from when I was researching which sim to get. I remember reading something about how CPU's that share memory for video processing don't play too nicely with high memory users like flight sims. That said, it's funny that your other ones don't have issues with your setup. I have a laptop that I run FS One on that has a switch to let me choose between the GeForce 7400 card and an oboard video (I think that's what it's for) so I'll try to switch back & forth to see if it makes a difference on that machine at least.
Dave
I actually solved this problem. I had to install symbols and a debugger to do it but, it turned out to be the ac3filter.ax codec that was causing the issue. I searched for all instances of ac3 and renamed them and the problem went away. Renamed them back and the problem returned. So far with the registry entries renamed, no issues. If I find something that disabling ac3 breaks I can rename them back.
