ORIGINAL: slogan
velineon setup in a traxxas stampede good speed,after 25' or 30' stalling, several new locations,same result, the set-up is the original lay out.
Make sure that there is no damage to the antenna on the truck. Also make sure that the AA batts in your TX are good. 25' is REALLY short. Are you using the antenna tube? TX antenna fully extended?
