RE: short range in stampede
I'd try a new RX if all else is good. Make sure your antenna doesn't come in contact with carbon fiber,graphite, aluminum, etc. What kind of batteries are you using, and do you have your lipo cutoff turned on? Maybe if your binding and geared too high, using poor batteries, it could cause the lipo cutoff to engage if its on, and you're using nimhs. Do you still have steering when it stops you?
