RCU Forums - View Single Post - Wing jig question for friend
Old 02-09-2009 | 09:30 PM
Campgems
Default RE: Wing jig question for friend
ORIGINAL: pdm52956
I'm just a painter, what do I know, but it seems to me that since the jig is designed to build a certain amount of washout into the wing using a certain dihedral, wouldn't changing the dihedral by raising one side change the washout you got from that jig? Otherwise why jig both wings at one time so that they were an equal distance from the table top?
If his table isn't long enough, wouldn't it be better to measure the table top from the floor and let the other wing over hang that height plus the 2.5". Otherwords, if the table top is 36" above the floor, let one wing hang over the table 38.5" above the floor. Weight it down (pin it, clamp it, what ever) in the center so it didn't move and go for it. At least that way he could do one side at a time while the dihedral was correct. Then switch the wing and do the other side. I don't know, I think I'd probably find a floor and clear the dog off of it and use that instead. Then you could be sure. Just my thoughts.
The dihedral if fixed by the diherral brace. At the point you using the jigs, the dhidral has been established. What you are doing is putting a twist into the wing so angle of attack decreases as you progress to the wing tip. The method used in this kit is basicly to give you one setup and let you put the top sheeting on without changing the setup. As you are working basicly using the root ribs pinned to the table and the tips raised, you are only working one pannel at a time. The relationship you are establishing is from the root rib to the tip, not tip to tip. The dihedral was established on page 30 of the manual. These jigs will not change it, but only put the twist in. If you could setup the jig correctly, you could accomplish this task with the wing vertical vs laying on table.
Don
