ORIGINAL: sawdust
...If you move the stick toward the nose of the plane, the plane comes toward you. If you move the stick toward the tail of the plane it goes away from you. This always works. It is an absolute truth...
Rules of thumb like this are oversimplified and are NOT always true.
If the plane is directly in front of you, and flying straight at you, then what??? Moving the stick towards the tail (forward) makes it dive into the ground, and moving it towards the nose (backward) makes it climb. If you end up underneath the airplane, then what?? IMO, these "rules of thumb" are just a crutch that some beginners use, but they don't do them much good in the situations described above.
The idea behind picturing yourself in the cockpit of the plane is to get you to change your control perspective as the plane's orientation changes, it is NOT intended to make you think the control perspective never changes. It is a complicated thing to learn, and the best way to learn it is lot's of practice. Again, a sim is the perfect tool to learn it.
